Egress Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-31-2010, 06:39 AM   #1
Egress window
THE building dept. in N.J. is not opened today. THE question is i have a twin casemant window 54 1/4 x43 1/2 that does not meet e gress now by code (i dont think thier is one for replacemant windows) can i install two d/h windows instead ?
all vinyl is offline   Reply With Quote
Old 07-31-2010, 12:42 PM   #2
Registered User
Rewards Points: 5,466
Notice the height/width ratio in the chart: http://illowaicc.org/uploadedFiles/I...20Openings.pdf
If a basement window on grade, slightly smaller area required: http://www.aacounty.org/IP/Resources...ementGuide.pdf
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
all vinyl (07-31-2010)
Old 07-31-2010, 03:38 PM   #3
Fantastick
JUST WHAT I NEEDED ALMOST BOUGHT THE DOUBEL HUNGS ty ty ty
Bedroom window egress codes drtbk4ever Remodeling 21 02-27-2013 02:21 PM
Egress window dimensions ClnlBrahm Building & Construction 28 12-22-2010 12:23 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 10:00 PM
DIY Egress window in basement? ClnlBrahm Building & Construction 5 09-03-2008 11:15 AM
