Old 06-22-2010, 05:16 PM   #1
egress window
do I need a steel lintel when I cut a window into a concrete foundation . Apx 48"x 48"
cameroncoker is offline   Reply With Quote
Old 06-22-2010, 07:21 PM   #2
egress window
The opening would be cut just under the sill plate, so I would install a simple header for the span You would only need to add a lintel if you were holding up a brick fascade.
Ron
Egress window dimensions ClnlBrahm Building & Construction 28 12-22-2010 01:23 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 11:00 PM
DIY Egress window in basement? ClnlBrahm Building & Construction 5 09-03-2008 12:15 PM
Egress Window Questions? cibula11 Building & Construction 12 03-15-2007 01:24 PM
