"effective" R-value For Spray Foam Insulation? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-23-2009, 08:49 AM   #1
"effective" R-value for spray foam insulation?
Hi,
I've been in contact with some contractors for spray foam insulation for the underside of a new construction roof. Although they say the foam has an R-value of 7 per inch, they say the 'effective' R-value is double that because there is no air movement within the material. Thus, I don't need 7+ inches to get R50, I'll only need 3.5-4 inches. Is this true?
red86yota is offline   Reply With Quote
Old 04-23-2009, 12:18 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Don't ask for ''inches of foam" ask for "R50".
Run this by your architect and local building permit office.
If the contractor signs up for R50, then there are legal issues if R50 is not installed.
Disclaimer
& Stay Safe
.....Bob Lavery
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Exterior Foam Insulation Help??? teachtech Building & Construction 3 11-29-2008 10:19 AM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
Venting foam board insulation mbscallen Building & Construction 5 02-15-2008 08:18 AM
