Old 09-22-2011, 01:40 PM   #1
Edge Distance for Drilling into Concrete
I will be installing four vinyl porch posts on an existing concrete slab that is 4" thick. The tapcon concrete screws I will be using are 1/4" x 2 1/4". How close can I get to the edge of the concrete without worrying about cracking the concrete?
JetMech642 is offline   Reply With Quote
Old 09-22-2011, 01:53 PM   #2
Framing Contractor
I would tr yto stay at least 4 inches away. Only drill as deep as you need to. They make tapcons that are shorter.
sixeightten is offline   Reply With Quote
Old 09-22-2011, 02:10 PM   #3
Architectural Designer
AGWhitehouse's Avatar
I agree with 4". We have gone as close as 3" with some designs, but unless you can ensure the concrete mix is strong enough I'd stick with 4".
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 09-22-2011, 07:00 PM   #4
We drill these things weekly and the installation calls for the post to be at the edge of the slab. We drill at 1 1/4" away from the edge. I've never had a slab break in the last decade or so.
TrapperL is offline   Reply With Quote
Old 09-22-2011, 08:50 PM   #5
DIY Hack
Mr Chips's Avatar
With Concrete Screws you want to maintain an edge distance of at least 6 anchor diameters, but keep in mind your tension and shear values are greatly reduced when you are this close. You need to be at least 12d from an edge to get full tension and shear
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
concrete under pavers around pool deck , pavers go to edge of pool doggie44 Landscaping & Lawn Care 0 02-27-2011 11:40 AM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General Discussion 9 04-11-2010 07:11 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
