Echo Sound In Floor Above Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-26-2008, 12:41 AM   #1
Echo sound in floor above basement
Hello...
I live in a new house with an unfinished basement. When I am walking down the hall on the main level there is a little bit of an echo. If I step 'loudly' the echo gets pretty loud. Kind of a reverberation in my ears type echo.
I was hoping to solve this problem before I finished the basement. Any ideas? I have put some 2 1/4" screws into the I-joists and main level sub-floor thinking maybe they weren't connecting all the way. And I put some shims between a beam and the sub-floor below the hallway.
I know I have been in houses with basements that had this problem, but how do you fix it?
Thanks for the help.
tandyt is offline   Reply With Quote
Old 05-27-2008, 12:11 AM   #2
any ideas?
Old 05-27-2008, 12:12 PM   #3
In that section of the house, how long is the joist span ? You could screw plywood on those joists (flange to flange) to stiffen them up.
raam is offline   Reply With Quote
Old 05-27-2008, 07:46 PM   #4
The hallway is an L shape and the echo spans the long part of the L which is equal to about 13' 6". There is a definite stop and start and stop to the echo. As in, if you stomped your foot in one spot, no echo, move over three inches, the echo begins. And keeps going for about 13' 6" and then has a definite stop again.
Old 05-28-2008, 09:41 AM   #5
I would see which way the floor joists are run. Perhaps some blocking will help.
Old 05-29-2008, 07:38 AM   #6
The floor joists run with the hallway. If you were to measure it out basically one wall is framed on one joist and the other is framed two joists over thus creating the width of the hallway.
Old 05-29-2008, 09:57 AM   #7
Any deflection (bounce) while walking ?
Old 05-29-2008, 07:29 PM   #8
Tough to say now since the floor is carpeted. But if you stomp on the floor semi-hard you can rattle everything around it pretty easily.
surround sound system echo cannouu Electrical 5 02-23-2011 10:13 PM
insulating a basement ceiling for sound JHill Building & Construction 15 02-27-2008 09:04 PM
Best "bang for the buck" in reducing basement sound floxy Remodeling 5 12-19-2007 06:19 AM
Soundproof Windows BlueJello General DIY Discussions 3 11-30-2007 06:34 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
