Old 05-19-2010, 10:51 AM   #1
Eave venting gable vent
I have been posting often trying to determine a solution. If I am going to use spray foam down to a kneewall and then treat the other side of the kneewall as a separate space, how do I know if the gable vents on each side will offer enough ventilation, or if I need power vents?
bfan781 is offline   Reply With Quote
Old 05-19-2010, 12:41 PM   #2
Totally screwed together
You should keep your posts on the same project under the same thread. Right now, no one knows what you are talking about. Post the link to your original thread where you discuss you rproject.
xxPaulCPxx is offline   Reply With Quote
10x16 eave vent intake - buy or make Rald Roofing 2 01-29-2010 06:46 PM
Soffit venting vs. DCI Smart Vent JDPII Roofing 1 02-28-2009 09:42 PM
Venting bathroom vent thru dryer duct jredrocker HVAC 2 09-27-2008 11:25 PM
Ridge Vent > Gable Vent jelly Roofing 10 06-09-2008 08:30 AM
