-   -   Eave venting gable vent (http://www.diychatroom.com/f19/eave-venting-gable-vent-71606/)
bfan781 05-19-2010 10:51 AM
I have been posting often trying to determine a solution. If I am going to use spray foam down to a kneewall and then treat the other side of the kneewall as a separate space, how do I know if the gable vents on each side will offer enough ventilation, or if I need power vents?
xxPaulCPxx 05-19-2010 12:41 PM
You should keep your posts on the same project under the same thread. Right now, no one knows what you are talking about. Post the link to your original thread where you discuss you rproject.
