Easysand Or Durabond For Setting Metal In Plaster Walls? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-04-2009, 11:25 AM   #1
Rewards Points: 188
Easysand or Durabond for Setting Metal in Plaster Walls?
When embedding a metal object in plaster walls (for an example like an electric receptacle box) is Easysand tough enough to hold up and not crack? Or is Durabond called for?
Do either of these stick well to metal?
Lovegasoline is offline   Reply With Quote
Old 12-04-2009, 11:32 AM   #2
Remodeling Contractor
Both will stick. Durabond is the way to go. dries faster and harder.
Old 12-06-2009, 02:25 AM   #3
Rewards Points: 188
Durabond base is on. I'll top with Easysand.
Thanks Bob.
Old 12-06-2009, 03:18 AM   #4
Too Short? Cut it Again!
Hold the phone. You cannot float or imbed an electrical box in Durabond, plaster or anything else. You need to screw, nail, or otherwise anchor it to something structural first like a wall stud. And I would use real plaster or plaster repair material for anything substantial in an existing plaster wall. The materials you mention are alright for light surface patching on top of plaster but not for anything major. They expand and contract at different temps than plaster just to start and even Durabond has nowhere near the density of plaster.
Old 12-06-2009, 06:12 AM   #5
I am not assuming that this box is not fastened. And it seemed more the question was about if the durabond will stick and not crack around a metal object.
Old 09-01-2013, 02:18 AM   #6
Rewards Points: 188
And right you are Bob.
The boxes are mounted to wood studs (the latter are oriented wide face parallel to the wall).
I used Durabond for the deeper fills; then Easysand. And some joint compound for the final skim coat touch ups.
The work is almost four years old and solid as a rock.
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 05:58 PM
Some crazy mud / plaster stuff on my walls in the new house Skeletor916 General DIY Discussions 2 01-06-2009 07:04 AM
Repairing cracks in plaster walls BlueGuy Carpentry 4 07-24-2006 01:44 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
ARCHWAYS in PLASTER WALLS tmacwith Remodeling 2 03-05-2006 09:24 PM
