Easy Ways To Mix Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-05-2011, 12:13 PM   #1
Easy ways to mix concrete
I am looking for easy ways to mix concrete without having to rent or buy new tools. So far, from my research on the web the best way seems to be to spread a tarp on the ground and just roll the mixture back and forth. Any other easy suggestions?
Gandalf is offline   Reply With Quote
Old 11-05-2011, 12:19 PM   #2
Rewards Points: 6,652
How much are you planning on mixing, and what are you using it for? If just a small amount, a five gallon bucket and small potting shovel works. Larger job like a patio, means you are renting equipment.
Old 11-05-2011, 12:24 PM   #3
Old School
Willie T's Avatar
Frankly, that sounds insane.
Willie T
Old 11-05-2011, 01:21 PM   #4
You did not mention what tools you have or how much Concrete you want to mix. Easy way would be a wheel barrow and a hoe or a small electric mixer that you should be able to find for $100.00 (or borrow from a friend)
CaptainD51 is offline   Reply With Quote
Old 11-05-2011, 01:54 PM   #5
kwikfishron's Avatar
Rewards Points: 998
Have a link to the rolling around on the tarp deal??? Never heard of such a thing.
A wheelbarrow and a shovel has always worked for me and most of the rest of the world.
Never liked the hoe much, usually end up breaking handles.
Portable mixers are a PITA imo.
Without a doubt the “easiest” way is to get someone else to do the mixing for you.
kwikfishron is online now   Reply With Quote
Old 11-05-2011, 01:56 PM   #6
Framing Contractor
OMG!!! Never heard of such a thing.
http://www.youtube.com/results?searc...+concrete&aq=f
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-05-2011, 02:11 PM   #7
@kwikfishron
check out instructables.com
http://www.instructables.com/id/Easy...th-a-Tarpauli/
Old 11-05-2011, 02:13 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That method has been around a long time but of course is in fact insane and obviously hasn't caught on. I think I saw it on one of those useless TV home improvement shows maybe Dean Johnson's show. In fact seems like that Miriam Johnson was talking it up one day on his show while two other guys were actually doing the work. What a mess!
It was being done by some tileguys I think.
Oh wait! If it was tileguys doing it then it must be a good idea.
The first time I saw it done was when I went to Rock Carpet school and that was the recommended means of mixing small batches of rocks and epoxy to make decorative logos from Rock Carpet. It was a nutty idea back then too.
Old 11-05-2011, 02:41 PM   #9
Old School
Willie T's Avatar
If I hadn't seen it, http://youtu.be/rYvUAflWi2U , I wouldn't believe it.
Willie T
Old 11-05-2011, 03:37 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well there ya go! Nuthin' to it!
First time I've seen the "Creter". Only times I've seen it done a basic cheap plastic tarp was used. I can see where the four handles would be a plus.
Old 11-05-2011, 04:02 PM   #11
Rewards Points: 998
The “CRETER”…..I like it.
I could see in certain situations where it would be quite handy. I wonder how much mileage you’d get out of those handles though.
Old 11-05-2011, 04:30 PM   #12
Framing Contractor
Rewards Points: 126
Idon't like that in step five they talk about putting it into a wheel barrow after mixing. What's the point of that? Cleaning up the tarp will be a mess too.
sixeightten is offline   Reply With Quote
Old 11-05-2011, 06:35 PM   #13
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,332
the tarp method is called "the wet italian". i did it once under someone else on the the crews orders... he read it somewhere and wanted to try it
the wheelbarrow method is what i do for small amounts.. anything more than a yard and i order it from a plant
woodworkbykirk is online now   Reply With Quote
Old 11-06-2011, 05:48 AM   #14
Rewards Points: 4,796
i'll be damned - see what i miss on late-nite tv by going to bed early ? ? ?
stadry is online now   Reply With Quote
Old 11-06-2011, 10:03 AM   #15
Rewards Points: 154
There are some plastic bags you can buy where you load in the concrete mix and a measured amount of water and roll it around the ground a few times. thecementsolution.com Or I suppose you can double up on some compactor bags and do the same thing, for mixing small amounts of course.
ovahimba is offline   Reply With Quote
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 01:20 PM
Concrete in crawlspace algored2deth Building & Construction 4 05-03-2011 01:28 PM
Plumbing line in exterior concrete for pool Hawk334 Plumbing 4 07-04-2009 10:13 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
