Easy Basement Insulation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-06-2011, 08:43 AM   #1
So I'm getting ready to install foam boards on my basement walls but I have some obstructions (plumbing stacks from upstairs, main water line) that are very close to the unfinished walls. Do I just use a smaller thickness foam board behind these obstructions then spray foam / tuck tape to seal it to the larger thickness foam boards or should I move the obstructions out away from the wall?
koz123 is offline   Reply With Quote
Existing Cathedral Ceiling Insulation Question Bob Deb Building & Construction 8 12-07-2010 07:54 PM
basement insulation - condensation behind the batt insulation natalie Building & Construction 3 01-31-2010 10:19 AM
Basement Insulation and humidity control mcwolfe6 General DIY Discussions 11 01-28-2010 06:02 PM
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 08:19 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
