Old 02-17-2011, 05:25 PM   #1
Earth to wall clearance issue
I have an old 1915 detached garage that sits on a slab that I need to change grade around. Currently I'm lucky if there is 1-2" from the ground to the bottom of the wall. Obviously that isn't enough and I'd like to come up with a good solution to better protect the wood from rot/insects.
Shy of jacking the garage up and pouring a new base under the garage, I'm open to suggestions. I just don't have the time/money to do that yet, but I may down the road.
I have thought about replacing the bottom 10-12" of siding with cement board and flashing. I've also thought about cutting the bottom 9-18" of wall out and replacing with concrete block. That method would actually match my house, as it sets on about 4 courses of block foundation above grade.
My neighbor whom is a brick mason, suggested pouring a shallow footing all around the perimeter of the garage and installing a short stone/brick veneer around the garage. It's something he did to his and it looks good and would protect from everything I want and allow for a slight buildup of grade, but wouldn't match my concrete block foundation of the house.
Any other ideas?? I can post pics if need be....
Master Brian is offline   Reply With Quote
Old 02-17-2011, 06:18 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... No chance of lowering the surrounding grade, eh,..??
Old 02-17-2011, 10:12 PM   #3
If only it were that easy!
I actually have had to build most of the yard around my house up to keep water out of the house. So far water hasn't gone towards/into the garage, but the ground does slope that way.
Old 02-18-2011, 08:22 AM   #4
011010100110111101100101
Dig a trench around the garage, then run a pipe down slope from the trench Fill the trench with gravel. Water will enter the gravel, the pipe, and flow away from the garage.
anesthes is offline   Reply With Quote
Old 02-18-2011, 12:09 PM   #5
I have thought about that, but currently don't have anywhere for the water in the pipe to go.
*I did uncover an old cistern, which I have thought about trying to bring back to life. If I could do that, I could divert the water into the cistern.
What about the garage wood framed wall and it's proximaty to the soil. Should I not worry about that?
Old 02-18-2011, 12:43 PM   #6
Well, I've always been concerned with ants. Wood boring insects will eat away at sills and studs. If you have a path where soil touches or reasonably is close to wood, they will find it.
I had to tear down an addition because of this.
-- Joe
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-06-2005 12:03 AM
