Old 02-05-2012, 07:30 PM   #1
Durock for siding?
Has anyone any experience using durock for exterior siding, with an elastomeric stucco top coat
john e k is offline   Reply With Quote
Old 02-05-2012, 08:40 PM   #2
Disabled wood vet
titanoman's Avatar
Durock for siding?
Instead of a brown coat?
Sounds kinda crazy to me.
Maybe you could tile the outside?
That would look rad.
What do you have now, osb?
I really doubt if it could handle the elements.
But let's wait for someone in the underlayment section to respond because I'm not sure about such things.
titanoman is offline   Reply With Quote
Old 02-06-2012, 06:54 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Durock for siding?
durock isnt what you want for your base. standard practice around here is a layer of denshield over the studs then 2" of foam.. from there the finish coat know as dryvit or elastomeric stucco..... however if you live in a freeze thaw environment you may want to rethink using such a product.. its doesnt hold up at all.. there are many commercial buildings that gt that treatment but within 3 or 4 years the finish is failing
woodworkbykirk is offline   Reply With Quote
Old 02-06-2012, 07:23 PM   #4
Durock for siding?
Durorock will work on the outside, but I am with Kirk on how to do this.
framer52 is offline   Reply With Quote
Old 02-06-2012, 10:08 PM   #5
Durock for siding?
the difference between denshield and durock is that the denseshield is water proof. where the durock is just mold proof and not water proof
Gap between tub and durock (not lip) megablok Flooring 19 04-05-2012 11:15 AM
replacing tile on durock, how to repair part of durock board already on floor? gared@roadrunne Tiling, ceramics, marble 1 01-15-2011 06:01 PM
Waterproofing Durock? ryan5068 Tiling, ceramics, marble 13 08-28-2010 11:39 AM
Stability of Durock vs plywood? Hossenfeffer General Discussion 6 07-15-2010 04:25 PM
Bathroom - Durock murphy54 General Discussion 12 02-10-2008 10:12 PM
