Durock To Drywall Joint - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-22-2014, 01:56 PM   #1
Rewards Points: 85
durock to drywall joint
I am getting ready to place my wall tile. I am not tiling the whole bathroom so ran the Durock just past the vertical shower door post and then ran drywall up to the Durock. I used the mesh tape and thinset to seal the joint. My question is I will have to install some tile over this joint and I have primered the drywall. Will I need to remove the primer where the tile will be over the drywall, or can I just rough up the primer, just worried about the thinset adhering to the primer.
boilermaker27 is offline   Reply With Quote
Old 05-22-2014, 02:03 PM   #2
Rob
Robpo's Avatar
Rewards Points: 826
thinset will adhere to the primer.
Robpo is offline   Reply With Quote
The Following User Says Thank You to Robpo For This Useful Post:
boilermaker27 (05-22-2014)
Durock secured on top of drywall for shower walls? darsunt Tiling, ceramics, marble 5 11-12-2013 01:53 PM
Durock / Drywall outside corner help Trucon01 Kitchen & Bath Remodeling 3 03-18-2013 06:24 PM
Bathroom floor - Kerdi Band for Ditra / drywall joint? Airgibson Flooring 12 08-04-2010 10:33 PM
Durock (CBU) to Drywall transition HELP Honeydo_MD Drywall & Plaster 5 03-28-2010 10:50 AM
Durock (CBU) to Drywall Transition HELP Honeydo_MD Drywall & Plaster 1 09-16-2009 12:24 PM
