Durock - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-30-2013, 08:54 AM   #1
durock
Where can I get some guidance putting up durock.
joexavier0311 is offline   Reply With Quote
Old 12-30-2013, 08:55 AM   #2
It pulls away when screwing and the corner broke up. Do I need to replace it or is there a fix?
Old 12-30-2013, 08:55 AM   #3
Rewards Points: 13,458
On there web site would be the best place.
joexavier0311 (12-30-2013)
Old 12-30-2013, 09:07 AM   #4
Rewards Points: 660
Or YouTube.
Are you using the correct screws? The head should be flush with the edge, not recessed like drywall.
Yes the edges can be a bit more difficult than drywall. I would get the inner body of the board screwed first.
B
Beepster is offline   Reply With Quote
The Following User Says Thank You to Beepster For This Useful Post:
Old 12-30-2013, 09:10 AM   #5
Can the corner be repaired or should I replace the whole thing? The screws say for durock.
Old 12-30-2013, 09:39 AM   #6
Got a picture so we can get an idea why it broke.
And not can not be fixed.
Trying to screw it to close to the edge may be the issue.
You can use galvanized roofing nails instead of screws.
Old 12-30-2013, 10:22 AM   #7
I was close to the edge. I'm going to get those nails.
Old 12-30-2013, 12:35 PM   #8
Thanks for the help. Apparently I was just going at it to hard. I slowed down and started taking it easy and no more problems. So far. Again, Thanks.
Old 12-30-2013, 04:30 PM   #9
DIY staff
Rewards Points: 7,174
Use tilers mesh and thinset to seal the seams and fix any gaps----the cracked corner can be filled---
Seal durock to cast iron shower receptor? rightit Tiling, ceramics, marble 2 12-08-2012 04:44 PM
Fixing my Durock Mistake ScubaGeekNC Flooring 12 05-24-2012 07:48 PM
Gap between tub and durock (not lip) megablok Flooring 19 04-05-2012 10:15 AM
Liner and Durock placement rightit Kitchen & Bath Remodeling 7 03-13-2012 06:35 AM
Durock Question md2lgyk Concrete, Stone & Masonry 7 02-18-2012 07:25 AM
