Dumb Siding Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-23-2008, 11:48 AM   #1
1610 CUB's Avatar
Rewards Points: 150
Question
Dumb Siding question
I have been wanting to put in a new door out the back of my garage, a mower door, I framed in a 6'W X 7"H door frame all done on the inside of the garage, the siding is untouched. I want to frame up doors thet will swing out. (2- 2'11 3/4" X 6' 11" doors).
Question: Do I remove all the siding install the j channel then cut and fit the siding or do I cut the hole then add the j channel? I hope this makes sense
1610 CUB is offline   Reply With Quote
Old 08-23-2008, 12:24 PM   #2
Eibwen
Remove the siding [I'm assuming its vinyl] back to the first break and finish installing the outside of the door. This will give you enough room to flash and mold around the door properly.
Then install your track around the door and cut the siding to fit.
A zip tool to undo/rezip the siding is a must have and they are only a few bucks at the big box.
Sammy is offline   Reply With Quote
Old 08-23-2008, 01:26 PM   #3
1610 CUB's Avatar
Rewards Points: 150
Sammy, got a link to a "zip tool" so I know what I'm looking for?!
Old 08-23-2008, 01:33 PM   #4
1610 CUB's Avatar
Rewards Points: 150
Sammy, I found out how to use it and what it looks like here http://homerepair.about.com/od/exter...ng_ziptool.htm
Thank you
Old 08-23-2008, 04:08 PM   #5
Eibwen
Thats it!
Makes it real easy to pop off the siding and put it back on.
Vinyl siding question? kcrossley2 Building & Construction 5 12-18-2006 05:20 AM
question on installing stucco siding? Rusty Bottoms Building & Construction 7 10-27-2006 02:26 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
