#1 |
ductwork through floor joists.
As part of finishing my basement I want to improve the head room. Is it safe to try and pass the HVAC ductwork through the bssement ceiling/ first level floor joists? If yes, what is the proper way?
#2 |
By not cutting into the floor joists.
#3 |
would like to do the same in our exercise room however i do NOT want my kitchen to fall down
no, it ain't safe NOR is it allowed by code
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
Framing Contractor
If they are 2x material...you can't do that, Period!!! If they are I-joists you can.
Joe Carola |
#5 |
Thanks all for the responses. I have two "dumb" beginner questions.
1) how can you tell a floor joist from a floor truss and what is the difference? 2) what is an I-joist and what does it look like. Details are good :-) Thanks! |
#6 |
Mod
Pic 1 are standard floor joist. Pic 2 are the I joist.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. |
#7 |
Average Joe/ex-Navy IC3
If there is enough room up in the joist bays, yes you could run the duct work up there. the problem lies, when you come across where electrical and water piping is, then you may not have enough room.
#8 |
So, from the photos (thanks) it would seem I have I-joists. My next question would then be..per Joe C. Reply what is N "safe or best practices" when running HVAC ductwork thru I-joists? Is there a metal/alloy frame I should place into the cut hole to support it with, etc.)
Thank you gents. |
#9 |
Depends on where the vents are located on the floor above. You would normally run the parallel between the beams or joists, and the trunk would stay as close to the middle of the house. Keep in mind, due to you are wanting to relocate the duct work, you have to take into account, that you could end up changing the design of the system overall, and may or may not cause problems with air flow.
How are the ducts running now? Post a picture showing. When you do take the picture, stand back and take an overall shot of the area, not a close up. |
#10 |
Here are dome photos of the situation. As you can see the duct runs perpendicular and below the joist (with one or two trusses thrown in) . I would like to continue them in the same direction ( because those areas they go to will still need HVAC) but raise them and go through the joists( in a narrower duct if need be). Is this advisable? What is the proper safe way to accomplish this?
Actually app keeps crashing when i attach photos. I will log in via my laptop soon and upload that way. |
#11 |
You are fine to leave it as is. You will just have to box in the trunk area. Where the clean out plug is, you should put in an access panel, so it is easy to get to, without having to cut into the gypsum later on. As for that huge bundle of Romex, that does need to be cleaned up, so it is not just hanging there. The one thing that I would do, if you are planing to put in the basement a movie or rumpus room, is maybe use Roxwool between the bays, to help deaden the noise, along with using 2" Blue poly caulked in place around perimeter of the foundation, at the joists, or use Tiger Foam to help seal, if you are planning to completely finish the space.
| Display Modes | |
| A/C and Ductwork Efficiency | Jessidog | HVAC | 1 | 07-29-2011 08:48 PM |
| Ductwork Insulation | tk3000 | HVAC | 3 | 11-19-2010 05:08 PM |
| plastic ductwork vs. metal: acoustic duct liners | jjpclev | HVAC | 5 | 02-26-2010 08:29 PM |
| Moving ductwork to accomodate finished basement | Badfish740 | HVAC | 1 | 01-13-2010 04:11 PM |
| Tapping into basement ductwork | BasementVirgin | HVAC | 7 | 09-10-2009 10:01 PM |
