Drywalll Only Mounted To Every Other Stud - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-05-2008, 11:37 AM   #1
drywalll only mounted to every other stud
I had some drywallers come in and do a room in my house and they only put screws into every other stud. It has already been mudded and is ready to paint. Now if you put your hand on the wall and press in there is quite a bit of slack in it. I'm worried that the joints are going to pop loose over time, but on the other hand I'm worried that if I run screws in where they left them out it's going to press in on the drywall and put pressure on the ends and cause those mud joints to come loose. Has anyone ever dealt with this before? What should I do? If I can get away with leaving it I'd rather do that but I don't want to have it come loose after I've got it all painted either.
matjone is offline   Reply With Quote
Old 01-05-2008, 12:53 PM   #2
Home Improvement Guy
ron schenker's Avatar
Are the studs 16" on centre? Are the sheets 4x8? Are they attached horizontally or vertically?
ron schenker is offline   Reply With Quote
Old 01-05-2008, 02:03 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Is it possible that some of the studs are bowed inward, and they didn't put screws in because it would have warped the sheets?
- Build Well -
Old 01-05-2008, 06:45 PM   #4
studs are on 16" centers. I went ahead and ran screws in because I don't want to have to come back after it's painted.
Old 01-06-2008, 02:12 PM   #5
You did the right thing by screwing to every stud. Sounds like your drywallers cut corners.
mathias is offline   Reply With Quote
drywalling a wall with one stud not level? yummy mummy Building & Construction 5 12-21-2007 03:22 PM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 12:28 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
Best reasonable stud finder??? Sellncars Tools 6 10-03-2006 08:29 PM
Stud Finder problem... kalaniwavo Carpentry 4 02-26-2006 07:24 PM
