Drywalling Over Tile - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2012, 09:09 PM   #1
Question
drywalling over tile
I have a tiled wall and need to cover it. should i drywall over it or is there something easier to do. i cant take tile down the other side of wall is a clock store with clocks all over the wall. if drywalling what steps do i need to take and how do i attach to tile
handyone is offline   Reply With Quote
Old 01-01-2012, 09:16 PM   #2
Rewards Points: 12,876
Good luck with that plan, it's not likly to stay stuck to the wall.
Dry wall adhesive may or may not work. It's just not normaly done that way.
Old 01-01-2012, 09:26 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by handyone View Post
...the other side of wall is a clock store with clocks all over the wall
have a chat with your neighbor and the landlord.
work something out.
Old 01-02-2012, 06:29 AM   #4
remove tile
so ur saying i need to just remove the tile What about covering it with something else. no,? wall is trade mark for another business. so we have to change it
Old 01-02-2012, 07:28 AM   #5
DIY staff
Rewards Points: 7,174
PL Premium will stick drywall to tile if you can not shake the walls--you will need to brace the sheets or mechanically fasten with enough screws to keep it in place until the glue sets.
The technique that works best---apply PL Premium to back of sheet---press against the wall--pull it back---wait about one minute for glue to 'flash'--then press into place and brace or screw.
The 'flashed' glue acts like a contact adhesive and sticks faster.
Cover your butt---notify the clock shop the day before you plan on working on that wall---Just in case.....
Old 01-02-2012, 07:39 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by oh'mike View Post
.....cover your butt---notify the clock shop the day before you plan on working on that wall.....
^^^ This ^^^
- Build Well -
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 09:03 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 07:03 AM
Subfloor and Porcelain tile prep sugarhousemama Flooring 4 12-03-2010 07:47 PM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
