Drywalling Over A Concrete Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-19-2008, 10:02 PM   #1
Drywalling over a concrete Wall
I have read a lot about liquid nails vs concrete nails, what would be more recommended?
pbuech is offline   Reply With Quote
Old 10-19-2008, 11:16 PM   #2
Registered User
Termite's Avatar
Drywall should never be installed in direct contact with a concrete wall. Doing that would be asking for a myriad of problems. Treated wood furring strips should be fixed to the concrete wall with ramset nails, tapcons, or other concrete anchors. The drywall is then screwed to the furring strips. Drywall adhesive can be used to reduce the amount of screws required to install the drywall.
Old 10-20-2008, 07:14 AM   #3
Building A House
Yes, you must install furring strips . Otherwise you're asking for some nasty problems.
Ezekiel is offline   Reply With Quote
Drilling Through Concrete Wall rjordan392 Building & Construction 8 07-23-2008 07:30 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Best way to handle this - furring out concrete freeze wall J187 Building & Construction 10 05-14-2007 06:17 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
