Drywalling For A "no Baseboards" Finish - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-03-2008, 01:43 PM   #1
Rewards Points: 18
Drywalling for a "no baseboards" finish
Typically, I see that it is recommended to hang drywall starting with the top course. In my application, however, there is NO baseboard, and the finished drywall butts the floor, which essentially removes the margin for error afforded with typical drywall hanging.
So in this case, is it acceptable to start with the bottom course, butted to the floor, leaving either the top course or a middle course to be finished last? (If it matters the new partition is 8'11" tall so I guess I could hang 12 foot sheets vertically)
VistaV is offline   Reply With Quote
Old 02-03-2008, 02:40 PM   #2
Is the flooring down yet? The only thing about starting at the floor is that you'll have to cut the taper off of the sheet before you start stacking them. We did a job like this once where the architect specified no baseboard(Big PIA). We started at the top and just used vinyl stop bead where the drywall met the floor(polished concrete). The cuts have to be very accurate. How is the existing drywall finished where it meets the floor?
jerryh3 is offline   Reply With Quote
Old 02-03-2008, 02:59 PM   #3
Rewards Points: 18
The flooring is what it is.
I have integrated color concrete floors. The rest of the house is simply drywalled to as close to the floor as possible - basically butted right against. I don't think there is anything between floor and drywall actually - at least I can not see it and I do not recall anything there when we built the house.
I am thinking I should use 12 foot drywall and install vertically.
I also had another thread about installing the new drywall next to exisitng corner round.
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
Stair Finish - wood or paint TRM Painting 3 01-16-2008 12:33 PM
Clear Hardwood Floor Finish With Buildup CuCullin Flooring 3 11-18-2007 02:26 PM
cabinet maker's finish jim_k Painting 5 08-03-2007 01:37 PM
