Drywalling Garage Ceiling: Joist Hangers Protruding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-19-2009, 12:03 AM   #1
Drywalling garage ceiling: joist hangers protruding
I am going to put drywall and insulation on a garage stall which was added to an existing garage. The ceiling has trusses on the inside half and half-width joists at 90 to the last truss which is beefier. The problem is that some of the joist hangers protrude under the truss almost 1/4".
The question is how forgiving is the sheet rock with this? Do I need furring strips?
rdy2go is offline   Reply With Quote
Old 04-19-2009, 06:43 AM   #2
you can do the strips or notch out the back of the sheetrock. PIA buts faster than adding strips.
II Weeks is offline   Reply With Quote
Old 04-19-2009, 07:30 AM   #3
Yes, carving out some from the back would be faster than nailing strips all over.
Now another thing just hit me. How do you handle sheet rock orientation when half of the ceiling has the framing one way and the other half is perpendicular. Have not measured, but all seem to be at 24 OC. May be I can post a couple of pictures later today.
Garage ceiling joist support mountainmike Building & Construction 11 02-28-2009 07:16 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Joist Hangers handy man88 Building & Construction 1 10-28-2007 10:12 PM
Ceiling Joist Beam Construction? Stargazer Building & Construction 1 08-26-2007 10:50 PM
Garage Ceiling Joist Question ejarlos Building & Construction 3 07-11-2007 06:27 AM
