Drywalling Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-29-2009, 09:31 PM   #1
zpm
yeah, right
Drywalling Garage
Have a single story house with an attached garage. The wall connected to the house has 5/8 drywall, floor to peak, sealing the garage from the house attic. Rest of garage is open framing.
Is it OK to use regular 1/2 drywall on the remaining garage walls and ceiling?
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 07-29-2009, 09:38 PM   #2
Is there any living space above the garage?
If so 5/8" required on the ceiling
Old 07-29-2009, 09:53 PM   #3
zpm
yeah, right
Originally Posted by Scuba_Dave View Post
Is there any living space above the garage? If so 5/8" required on the ceiling
spiders live there ... "Have a single story house" ...
Old 07-30-2009, 12:35 AM   #4
Registered User
Rewards Points: 4,894
As long as the drywall on the ceiling is not getting any water based spray texture and the sheets are installed perpendicular to the framing, either 16" or 24" on center. Otherwise, 5/8" is required according to the manufacturers that write the application codes. Page 3, table 1, footnote B: http://www.gypsum.org/pdf/GA-216-07.pdf Your local jurisdiction may state differently. Be safe, G
Old 07-30-2009, 08:45 AM   #5
RippySkippy's Avatar
In our area...ceiling AND connecting walls must be 5/8". Check with your local code officials to be certain.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 07-30-2009, 08:46 AM   #6
zpm
yeah, right
Thanks for the info and document. It will be useful.
I think I'll just go with 5/8 since I may decide to texture the ceiling later.
Old 07-30-2009, 12:10 PM   #7
Registered User
Termite's Avatar
Scuba Dave's right on as far as the code goes. The IRC code requires 5/8" on the garage ceiling only if there is habitable space above. The wall does not require 5/8" rock in any circumstance in the code.
Old 07-31-2009, 02:20 PM   #8
Registered User
Good choice, zpm. That is exactly why I stated the manufacture's application code, in case you put up 1/2" and textured it. Many houses I've had to frame drywall backing on the attic truss over the living space garage wall, in order to drywall to the peak on the truss for fire stop (as you posted). Builders found it cheaper than to drywall (5/8") the larger garage ceiling for fire stop.
Be safe, G
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 02:11 PM
Drywalling garage ceiling: joist hangers protruding rdy2go Building & Construction 2 04-19-2009 08:30 AM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
Garage Door Install marly General DIY Discussions 2 11-17-2008 03:51 PM
