Drywalling Bathroom And Shower - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 08:07 PM   #1
Drywalling Bathroom and shower
Hello All...I am in the midst of remodelling my basement bathroom and have a question about C/B and sheetrock seams. I will be tiling the shower section and am using C/B as a backing, and am wondering if I should caulk or seal the seams with anything, or if tile mortor itself will suffice. I have seen and heard of people siliconing or even tuck taping C/B joints but always wondered if nescessary. I am also using the Schluter shower system and am thinking that sealing the C/B joints may be overkill or create a problem with adhesion for skirting compound.
Any help is much appreciated.
Golfing Canuck is offline   Reply With Quote
Old 01-11-2010, 08:13 PM   #2
most guys I know just tape all the seams and screws with the thin set they'll use for the tiles.
silicone used to be the norm but not so much anymore
II Weeks is offline   Reply With Quote
Old 01-12-2010, 08:24 AM   #3
ccarlisle's Avatar
Depends a bit on the layout and size of tile you're putting there. If it's smaller tiles, then taping the joints with the special tape they have for that is required, otherwise if you're going with bigger tiles, then you may not need to.
But good for you for 'waterproofing' the shower...!
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
Is it ok to use the shower without a ceiling in the bathroom? Bigguy0 Building & Construction 5 10-24-2009 08:26 PM
Bathroom remodel - recessed light above shower bigburb Remodeling 6 10-02-2009 01:03 AM
Framing Shower Wall in Bathroom Justin LaRue Kitchen & Bath Remodeling 2 06-30-2009 11:34 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 11:33 AM
