Drywalling 24oc Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-20-2009, 11:34 AM   #1
drywalling 24oc wall
I'm about to hang drywall on the walls in the basement after rocking the ceilings. The perimeter walls are poured concrete and pre-studded 24in oc. Ceiling height is less than 8 ft and lower where I have soffits for ductwork. I already bought 4x8 drywall panels 1/2 inch thickness. I'm leaning towards hanging vertically if I finish with tape, mud and sand myself because hiding tapered seams is easier for the drywalling novice. But I also want to get an estimate if I hire out the taping and mudding and professionals usually hang and finish horizontally. So anticipating that I may give in and pay someone to mud and sand, should I hang horizontally? Will the 24oc stud spacing cause more flex with the tapered edges if installed horizontally leading to cracks or is that not an issue? I guess lifting the sheets horizontally will be a challenge but I need someone to recommend the horizontal. If I had bought 4x12 panels, horizontal would be a no-brainer but i already have the 4x8 sheets. Thanks in advance for your help!!!
8roty is offline   Reply With Quote
Old 12-20-2009, 11:41 AM   #2
Remodeling Contractor
with 24" OC studs you must use 5/8" drywall.
Old 12-20-2009, 11:47 AM   #3
I read that minimum is 1/2 inch for 24oc, 5/8 is better...less flex but that's what HD sold me and I didn't specify....limited knowledge of drywalling basics.
Old 12-20-2009, 11:47 AM   #4
Either way with only 1/2" may lead to cracks
1/2" will flex quite a bit 24" OC
Old 12-20-2009, 11:49 AM   #5
HD is about your worst source for information or materials.
Old 12-20-2009, 11:51 AM   #6
Will installing horizonatally create issues with this added flex? Should I add blocking between the studs for added support?
Old 12-20-2009, 11:57 AM   #7
Yes to both questions.
Shamus
Shamus is offline   Reply With Quote
Old 12-20-2009, 11:59 AM   #8
So the recommendation is to install vertically with blocking?
Old 12-20-2009, 12:34 PM   #9
Edit:
Either way I would use blocking. 1/2" with 24" oc needs some support
Shamus
Old 12-20-2009, 02:20 PM   #10
Rewards Points: 1,016
Suggest to take the 1/2" back to HD and swap for 5/8". It's a lot of work for it to come out less than satisfactory by using the wrong materials, IMO.
Old 12-20-2009, 03:39 PM   #11
Registered User
Rewards Points: 5,216
You may use 1/2" on the walls, run either way:
Gypsum Panel Gypsum Panel Maximum
Product Thickness Product Orientation Framing Spacing
in. (mm) to Framing in. (mm) o.c.
Ceilings:
3/8 (9.5) A Perpendicular B 16 (406)
1/2 (12.7) Parallel B 16 (406)
1/2 (12.7) Perpendicular B 24 (610)
5/8 (15.9) Parallel 16 (406)
5/8 (15.9) Perpendicular 24 (610)
Walls:
3/8 (9.5) Perpendicular 16 (406)
or Parallel
1/2 (12.7) Perpendicular 24 (610)
or Parallel
or Parallel
A Shall not support thermal insulation.
B On ceilings to receive hand or spray-applied water-based texture
material either i) 1/2 in. (12.7 mm) gypsum ceiling board (ASTM
C 1396/C 1396M shall be applied perpendicular to framing; or ii)
other gypsum panel products shall be applied perpendicular to
framing and board thickness shall be increased from 3/8 in. (9.5
mm) to 1/2 in. (12.7 mm) for 16 in. (406 mm) o.c. framing and
from 1/2 in. (12.7 mm) to 5/8 in. (15.9 mm) for 24 in. (610 mm) o.c.
framing. See Appendix A.2. From: http://www.gypsum.org/pdf/GA-216-07.pdf
"Will the 24oc stud spacing cause more flex with the tapered edges if installed horizontally leading to cracks or is that not an issue? -------- Run with long side parallel to the studs, strength is = 46# per sq.ft. Run perpendicular to the studs, strength is 147# per sq.ft. Or more than 3 times as strong. May not be an issue if you don't have any children......
Some tips on hanging and finishing: http://www.taunton.com/finehomebuild...tt-joints.aspx
http://bestdrywall.com/files/ReduceCallbacks.pdf Prime before and after texturing: http://gypsum.org/download.html
Use floating ceilings and corners.
Be safe, Gary
Old 12-20-2009, 03:58 PM   #12
Must?
jerryh3 is offline   Reply With Quote
Old 12-20-2009, 04:22 PM   #13
or not.. I guess many except low quality work. But why? Is 5/8" that much more money for a wall that will look better?
Old 12-20-2009, 04:34 PM   #14
True. I would be afraid of someone bumping into a 24 o.c. wall with 1/2" drywall.
Old 12-20-2009, 05:22 PM   #15
Preference for running the sheets horizontally because this helps to keep joints on studs from showing up as easily. For all the work and effort I would recommend you take the sheetrock back and hire everything out. Those sheetrockers are brutes and for the work they do, the good ones, they are cheap.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 04:43 PM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 01:02 AM
