Drywall Weight - Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-14-2012, 12:04 PM   #1
Rewards Points: 150
Drywall weight - wall
I asked this question (amongst others) in the drywall forum, but thought B&C might be more appropriate for this particular question:
Are 3 layers drywall (two 5/8", one 1/2") on each side of wall (total 6 sheets) too much weight for the wall?
The wall in question is a solidly built 20' long staggered (2x4...total depth 5.5") stud wall that bears only the weight of the 2x8 joists for that room (16" centers). The joists are also screwed into a perpendicular joist from the next room. The wall is on a concrete slab.
There are already 2 layers of 5/8" on each side. 1st layer using 1 5/8" screws, 2nd layer 2.5" screws. 3rd layer will use 3" screws.
My thinking is that it will be fine, but I'd rather know that it'll be fine.
Thanks!
rightit is offline   Reply With Quote
Old 06-14-2012, 12:14 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
I am curious, are you trying to make a 3 hr. rated fire wall on both sides of this wall?
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 06-14-2012, 01:41 PM   #3
Sounds like that or a sound proof torture chamber.
Evstarr is offline   Reply With Quote
Old 06-14-2012, 02:09 PM   #4
Rewards Points: 150
Correct on the sound proof chamber (less torture, of course). Just want to make sure I have no structural issues before proceeding with the final layers.
Old 06-14-2012, 07:59 PM   #5
Rewards Points: 150
In case someone else is looking for answers: According to the sources I've talked to, no structural problems with 3 layers each side.
Search terms: Soundproofing, green glue, drywall weight, multiple layers
The Following 2 Users Say Thank You to rightit For This Useful Post:
Evstarr (06-15-2012), mae-ling (06-14-2012)
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Drywall Bulge after installed TV wall mount tstecko Drywall & Plaster 15 03-23-2010 07:35 PM
Replacing drywall without removing tile through an interior wall MLP Drywall & Plaster 6 08-06-2009 11:35 AM
Hanging Ceiling Drywall AFTER Wall Drywall? mfleming Drywall & Plaster 10 10-06-2008 03:32 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
