Drywall Trowels - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-13-2008, 08:57 PM   #1
Rewards Points: 93
Drywall trowels
Im working with drywall mud and finishing a job someone started. The person showed me the ropes and a few tricks. I got all my equipment but cant seem to find larger trowels that are 14" or more. The only trowls i can find is cement trowels and was wondering if these are the same thing? They look the same exact as the drywall ones.
simonb is offline   Reply With Quote
Old 05-14-2008, 06:39 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You need to locate a Drywall Supply House. They carry a large selection of plastering trowels.
- Build Well -
Old 05-14-2008, 08:18 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Drywall trowells have a very slight concave curve in the blade. Concrete finishing trowells do not.
Old 05-14-2008, 03:03 PM   #4
Rewards Points: 93
Thanks for the reply guys. I went to Rona and they have a 16" trowel for both, they look the exact same thing! I compared them and put them against a flat surface and none have a curve in them. The only difference is one is $16 and the other $45
Old 05-14-2008, 03:50 PM   #5
Registered User
Termite's Avatar
You shouldn't need anything wider than 14", or your methods are flawed. I think my widest knife is 12", and yes, it has a very slight curve (about 1/16" or less overall) on it.
You definately want the curve when building butt seams. You can't do a professional job with concrete-type tools.
When doing a butt seam, you should build two mounds with your curved trowel...Each slightly offset to each side of the seam. Once they're dry, you come back and fill in the seam, which is in the valley between the two mounds. This just can't be done with a straight blade. Overall, you'll probably have drywall mud spread to a certain degree over about a 20" width or so.
Old 05-14-2008, 05:38 PM   #6
FWIW: We use 12" Knives, as well, to finish drywall. I have seen some guys who like to use a 14" trowell to finish, but it's essentially, just 2 different methods to achieve the same thing...
- Build Well -
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Need Drywall Help looking4ideas Remodeling 1 04-01-2008 06:27 AM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
