Old 08-12-2007, 11:17 AM   #1
tenzo's Avatar
Drywall seams
My house is about 4 years old and some of the drywall in large vertical areas (like stairs) seems to be buckling slightly. Nothing major that needs replacing. Rather like a wrinkle in the paper that comes out 1/4"
It has been suggested that I sand these down and repaint. But I'm worried about sanding through the drywall paper and causing all sorts of propblems.
Ideas?
tenzo is offline   Reply With Quote
Old 08-12-2007, 04:01 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Drywall seams
Sounds very strange to me: Drywall "buckling" in a 4 year old home?
- Build Well -
Old 08-12-2007, 04:38 PM   #3
tenzo's Avatar
Drywall seams
just were the seams come together.
I'll see if I can get a pic
Old 08-12-2007, 09:44 PM   #4
Remodeler
MinConst's Avatar
Drywall seams
Are you saying the tape is coming loose? If so take it off and re-tape the seams.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 08-13-2007, 06:30 AM   #5
Drywall seams
If it is the seams, then do as MinConst. advised.
Do not do what someone else suggested in regards to simply, "sanding down" the area and painting.
- Build Well -
Old 08-13-2007, 07:37 AM   #6
tenzo's Avatar
Drywall seams
It's almost as if someone had cracked the drywall in half. Almost in two but not the paper on one side. (maybe the wall was not straight). Then they put it up and you have that little 1/4 bulge from the paper.
I'll get a picture later today
Old 08-13-2007, 09:27 AM   #7
tenzo's Avatar
Drywall seams
Staircase
You can got to: http://www.tenzo.org/hall.htm to see more picts and to enlarge.
Thanks for your help guys
Old 08-14-2007, 12:21 AM   #8
Drywall seams
can not tell from the pics what is going on but that is nasty looking.
warnerww is offline   Reply With Quote
Old 08-14-2007, 12:37 AM   #9
Drywall seams
Scrap and peel off the tape to find out what's going on. I wonder if there some foundation issues here. Also why does your staircase look all dented and chipped?
Krichton is offline   Reply With Quote
Old 08-14-2007, 07:30 AM   #10
Drywall seams
Seen this before. Use a utility knife to cut that wrinkled paper out. Re-tape and re-coat. Looks to be settling of the house.
- Build Well -
Old 08-14-2007, 09:29 AM   #11
yummy mummy's Avatar
Drywall seams
Can I ask what could possible have caused it to do that?
I am starting to have nightmares of my basement looking like that.
Any advice of what I should or shouldn't do, to avoid this?
Thanks.
(Atlantic, where have you been, vacationing?)
yummy mummy is offline   Reply With Quote
Old 08-14-2007, 10:49 AM   #12
Drywall seams
I believe those lines are could be caused by one of the below reasons: insufficient backing at the edge/joing between drywalls(most likely), and/or insufficient fastening when putting on the drywall/ or fastening was too much in and causing paper on drywall damaged....
basically, if drywall have backing on all edges, and enough screws, and screw got install properly... this shouldn't happen
well unless the wall move due to structure problem of the house which I assume this will not be the case... otherwise... there are more serious problems to worry about than those lines...
Real case is:
I think the installer, didn't bother to put extra blocking at the end of the drywall and the drywall end didn't fall into a stud, then when the two drywalls meet, they don't line up... then the taper try to do a favour by using the tape to force the joints be align may be together with some little screws here or there... overtime... this is not sufficient force causing the tape bounce out...
KUIPORNG is offline   Reply With Quote
Old 08-14-2007, 12:35 PM   #13
tenzo's Avatar
Drywall seams
KUI****G, you win the prize.
Yeah, after following the above sage advice I cut it out with a knife. The guy used the mesh tape, but over time it just didn't hold.
There are one or two other places where the drywall is doing that in the center of the wall. Basicall bowing out because they didnt use enough fasteners.
So I'm cuttin our the spots. Using drywall screws to anchor above and below it and then having a guy come in to mud it up.
What a PITA
But thanks to you guys, I can fix it.
Old 08-14-2007, 12:39 PM   #14
tenzo's Avatar
Drywall seams
cuz it is.
They used pine (soft wood) and it has a lot of knots and gets marked up pretty easy
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 06:59 PM
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 01:13 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
