Drywall Seam Separation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-04-2007, 07:37 PM   #1
Rewards Points: 150
Question
Drywall seam separation
Atlantic & Slick, hope ya'll will see this question. I'm starting on the hallway for the next project. At one of the seams of the drywall [by the way, are sheetrock and drywall the same thing?] the tape is lifting off along with the ceiling texture. It almost doesn't look like there was any mudding done because the tape is lifting off so cleanly, and the surface of the drywall beneath the tape is pristine.
[Recall I was bemoaning the shortcuts that the contractors took with this house when I was renovating Hubby's bathroom.]
Any way ya'll could walk me through this fix, step by step? Please don't make any assumptions regarding my expertise,,,talk to me like I'm a 1st grader if you like.
Val
shapeshifter is offline   Reply With Quote
Old 03-04-2007, 10:17 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Val
Remove the tape...by peeling and cutting with a utility knife. Remove any areas that are peeling. Scrape any loose areas of compound that my be flaking after you peel. Re-coat with new tape using the standard procedure for applying tape. Apply compound skim coating as normal (Like newdrywall)...Sand and paint...
- Build Well -
Old 03-05-2007, 09:52 AM   #3
Rewards Points: 150
Thanks Atlantic. I'll surf and see if I can find a video of how to apply the tape and mud.
Old 03-06-2007, 12:02 AM   #4
yummy mummy's Avatar
Rewards Points: 1,016
I found a site that shows you videos of how to do drywall.
www.drywallschool.com
Hope this helps.
yummy mummy is offline   Reply With Quote
Bathroom Drywall jeepwillies Drywall & Plaster 11 05-03-2011 01:04 PM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 06:59 PM
Patching drywall-where to place seam? AllGoNoShow Building & Construction 6 09-20-2006 12:02 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
