-   -   Drywall seam separation (http://www.diychatroom.com/f19/drywall-seam-separation-6888/)
shapeshifter 03-04-2007 06:37 PM
Atlantic & Slick, hope ya'll will see this question. I'm starting on the hallway for the next project. At one of the seams of the drywall [by the way, are sheetrock and drywall the same thing?] the tape is lifting off along with the ceiling texture. It almost doesn't look like there was any mudding done because the tape is lifting off so cleanly, and the surface of the drywall beneath the tape is pristine.
[Recall I was bemoaning the shortcuts that the contractors took with this house when I was renovating Hubby's bathroom.]
Any way ya'll could walk me through this fix, step by step? Please don't make any assumptions regarding my expertise,,,talk to me like I'm a 1st grader if you like.
Val
AtlanticWBConst. 03-04-2007 09:17 PM
Val
Remove the tape...by peeling and cutting with a utility knife. Remove any areas that are peeling. Scrape any loose areas of compound that my be flaking after you peel. Re-coat with new tape using the standard procedure for applying tape. Apply compound skim coating as normal (Like newdrywall)...Sand and paint...
shapeshifter 03-05-2007 08:52 AM
Thanks Atlantic. I'll surf and see if I can find a video of how to apply the tape and mud.
yummy mummy 03-05-2007 11:02 PM
I found a site that shows you videos of how to do drywall.
www.drywallschool.com
Hope this helps.
