Drywall Screws? Fine Or Coarse, Tip For My Drill - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-27-2007, 02:04 PM   #31
yummy mummy's Avatar
Rewards Points: 1,016
I don't have anything against cordless, and it's not a question of cost, it's that I really don't think I will get other use from it.
I already have a corded drill.
yummy mummy is offline   Reply With Quote
Old 09-27-2007, 02:15 PM   #32
mt232's Avatar
I think if you try the cheapo bit pictured above with your drill, you'll see that you can't overdo it, well, you can but not easy. The bit is made to drive the screw in, enough for the proper dimple, but not enough to rip the paper. Then the drywall holds the outer portion of the bit to keep it from ripping and damaging the paper, it won't let you go too far.
Try it, you'll get it.
mt232 is offline   Reply With Quote
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
recommendations for an all-purpose drill mcvane Tools 18 11-29-2007 09:12 AM
Drywall - Nails or Screws? digthisbigcrux General DIY Discussions 6 03-20-2007 04:31 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
