Drywall Screws? Fine Or Coarse, Tip For My Drill - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-26-2007, 08:22 AM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Drywall screws? Fine or coarse, tip for my drill
I am about to start hanging drywall, and would like to know which drywall screws are the best to use for hanging drywall? The fine thread ones or the coarse thread ones?
I assume the 1 1/4 inch are long enough?
Also, if I buy one of those tips to put on my power drill to hang the drywall, do they work well?
yummy mummy is offline   Reply With Quote
Old 09-26-2007, 10:39 AM   #2
Rewards Points: 150
Coarse thread, in my experience, is better. The more rotations is takes to get the screw in, the bigger chance to strip out the head. For 1/2" rock, I prefer 1 5/8". And it takes some practice to get it right, but I simply use a DeWalt dimpling bit. Clutch might be easier, but I never got around to buying one...
scorrpio is offline   Reply With Quote
Old 09-26-2007, 11:52 AM   #3
Weekend Builder
Crackers's Avatar
1 inch into the wood (min) is what I use as a guideline. For furniture making it is different as you use less nails and more joints...
Crackers is offline   Reply With Quote
Old 09-26-2007, 06:04 PM   #4
Eibwen
Definitely coarse thread drywall screws..
1 1/4" should be fine if your attaching directly to the studs.
As long as your speaking of the screwdriver bit with the spin off/dimpling cup on it versus just a regular phillips head bit then yes, they do o.k. for a homeowner. Especially if your cordless has a clutch setting on it you can dial it in and get good results on smaller jobs.
Sammy is offline   Reply With Quote
Old 09-26-2007, 06:17 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
It's already been covered by other members, but I'll clarify anyways. Since you have framed your basement with wood materials and will be installing 1/2" sheetrock, you should use: Course thread, 1-1/4" drywall screws. This is the industry standard.
FWIW: Fine thread is for steel. Course thread is for wood. Longer drywall screws are for double layer or thicker sheetrock.
They will work. You can give it a try. If you don't like what you see, then try a "drywall screw-gun".
The key to screwing in sheetrock is that you don't want the head of the screw to penetrate the paper surface of the sheetrock. If the screw head tears it, you will most likely end up with a "popped screw" in your wall. The paper surface is what holds the gypsum together. If you tear through it with a screw, then that screw is not holding the sheet.
Good Luck!
- Build Well -
Old 09-26-2007, 06:36 PM   #6
Mod / ArchiBuilder
Cole's Avatar
Cheap Route:
Better Route:
Both will be able to be used with any regular screw gun.
Cole is offline   Reply With Quote
Old 09-26-2007, 06:38 PM   #7
Mod / ArchiBuilder
Cole's Avatar
Or this:
Old 09-26-2007, 06:49 PM   #8
Eibwen
Wow... My wife always said I was cheap and now here is proof of it!
I got the cheapy but it works o.k. for doing a few sheets of drywall here and there.
Old 09-26-2007, 08:12 PM   #9
Mod / ArchiBuilder
Cole's Avatar
If you are just going to hang a couple of sheets and wont be doing any other drywall work in the future, the cheap version is the best imho!
Old 09-26-2007, 10:01 PM   #10
Good Luck!
Thanks Atlantic
If I use one of those bits that I would put in front of my drill, and I only bring it 3/4 of the way in and then finish it by hand, in that way I will make sure that I don't punture the paper.
Do you think this would be a better way since I have absolutely zippo experience in this?
Old 09-26-2007, 10:02 PM   #11
Cole
Thanks for the great pics.
Now I know what I'm looking for.
Old 09-26-2007, 10:05 PM   #12
I don't have a cordless, just a regular hammer drill that plugs into the wall.
I wonder if that will work.
The only thing is, that it is really heavy and I don't think I will be able to have good control, as I have to control it by hand, and sometimes it goes faster than I would like.
I will have to try, if not then I will be doing it by hand.
(Screwing them in by hand)
Old 09-26-2007, 10:28 PM   #13
Mod / ArchiBuilder
Cole's Avatar
You could always use nails?
Old 09-26-2007, 10:42 PM   #14
Yes, if your only driver is a hammer drill, I think you'll want to nail it with drywall nails.
NateHanson is offline   Reply With Quote
Old 09-26-2007, 11:06 PM   #15
Rewards Points: 150
Thanks Atlantic
You can't do this. You want to form a 'dimple' around the screwhead that will be filled with compound and hide the screw That is the purpose of that 'cup' on the bits shown. Finishing by hand you'll end up with no dimples and hiding screw heads will be almost impossible. Drive them all the way with the bit.
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
recommendations for an all-purpose drill mcvane Tools 18 11-29-2007 09:12 AM
Drywall - Nails or Screws? digthisbigcrux General DIY Discussions 6 03-20-2007 04:31 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
