Drywall Screw Inspection Requirements? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-29-2009, 01:47 PM   #1
Rewards Points: 77
Drywall screw inspection requirements?
I am starting to hang the drywall and my building department requires a screw inspection before I tape. What exactly are they going to be looking for? I am going off of what I read somewhere that you should use 7 inch spacing between fasteners on the edges and 12 on the studs in the middle, does that sound right?
So for the area in this picture (the edge of the ceiling), am I supposed to put wood where I put this red line so that I can meet the 7" requirement (I already passed the frame inspection and they didn't say anything about it) or can I just fasten the drywall edge to the spots where I have the red x's?
epeterson777 is offline   Reply With Quote
Old 03-29-2009, 01:51 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
You have to install a "nailer" board so you can place the screws where you want/need them.
the framing inspector didn't say anything about this because it does not affect what he was inspecting. It is soley for the purpose of attaching the sheetrock.
as to how close the screws need to be; I can't tell you but your building department may have their own requirements regardless what any other code requires. They are the best source for specific info.
Old 03-29-2009, 02:03 PM   #3
I've never been asked to have the sheetrock screw placement inspected. Rough, insulation, then final
Many people allow the edge near a wall to "float" & be supported by the side sheetrock. Myself I wouldn't worry about the ceiling edge. I'd mark where you have the 2x's (red X) & secure there
Then once you put the side sheetrock up it will be held in place
Your insulation seems to be pushed up pretty far
I like it down near the ceiling to prevent cold air from settling into that space
Old 03-29-2009, 02:09 PM   #4
Rewards Points: 77
The insulation is just there for sound control. I did a real quick job with it and realized half way through that it doesn't help much for the sound above anyways. This is a basement ceiling and the temp stays pretty constant the way it is.
I am just worried that I will hang all the drywall and they will say that I need to have it attached along the edges like that. They are pretty lax though since I am a homeowner.
Old 03-29-2009, 08:13 PM   #5
Rewards Points: 162
I've had inspectors review screw spacing in drywall before, but only on fire rated shaft walls.
Regarding spacing, the manufacturer of the wall board should have requirements listed on their website. Print it out and have it on hand should the inspector question your screw spacings.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 03-30-2009, 07:20 AM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
I've gone through the drywall inspection thing. My area wants 12" spacing on ceilings and 16" on walls. Nothing particular about the edges, or which direction the sheets run. Ladder bracing is OK as long as it meets the centers the same as the rest of the ceiling framing.
Old 03-30-2009, 08:56 AM   #7
RippySkippy's Avatar
Our local inspectors look for max of 6" between fasteners on the ends and a max of 8" in the field, regardless of whether it was glued or not.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 03-30-2009, 11:08 AM   #8
Drywall contractor
Rewards Points: 1,070
As nap said, call your inspection dept. and ask them. Screw/nail inspection is not required for residential drywall work around here. I'd advise using adhesive also....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-30-2009, 11:40 AM   #9
HABSFAN2006's Avatar
Rewards Points: 150
I don't have much experience with adhesive on ceiling drywall,
so what do you recomend? Something like PL ?
I imagine something with no expansion is important as to not pop the
screws out of the paper.
HABSFAN2006 is offline   Reply With Quote
Old 03-30-2009, 11:43 AM   #10
Rewards Points: 1,910
It would be silly to add nailers between the 16" oc framing but as the others said call the inspector. Sometimes you gotta do silly things to please them, sometimes not.
Old 03-30-2009, 11:48 AM   #11
Drywall contractor
Drywall stud adhesive. HD and Lowes both carry some sort, either DSA or OSI. Comes in a quart tube, so you'll need a large gun. Definitely does not expand. It will help lessen the likelyhood of screw pops if you get some lumber shrinkage/movement. Use on the walls too.
Old 03-30-2009, 12:29 PM   #12
Registered User
Rewards Points: 5,492
I wouldn't nail or screw closer than the last TJI to the corner. If you nail right up to the corner, cracks happen, as the materials(WOOD) moves, as others have correctly said. If inspector says to, add them in front of him. Sometimes, to save labor, I install 10' lengths of L - flashing, to screw to, at the junction.
If any more blocks, toe-nail them, as per manu. inst. Please read this: http://www.buildingscience.com/docum..._download/file I hate mold! Be safe, GBAR
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Deck screw in drywall? Ininkus Building & Construction 4 03-24-2009 03:36 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
