Drywall Screw Gun Or Screw Setter Bit ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-14-2011, 01:53 PM   #1
Rewards Points: 201
Drywall screw gun or screw setter bit ?
I have never installed drywall yet, but will be installing it soon on my house. I have 70 sheets of 5/8" and 48 sheets of 1/2" to install.
I am wondering if it would be worth it to go to the expense of buying a dedicated drywall gun (about $80), or if I could get by with just using one of the drywall screw setter bits that you can use with a cordless drill/driver (I already have the drill/driver) ?
Has anyone used both, and if so, how much better does the dedicated gun work ?
I also already have a cordless impact driver that I used to install my subfloor and noticed that I had better control in not over/under driving the screws than I had in using the cordless drill/driver.
Is that a viable option for installing drywall as opposed to the screw setter bit ?
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 06-14-2011, 01:59 PM   #2
Experienced
Jackofall1's Avatar
Personally, go with the dedicated drywall gun, they are lighter duty, but also lighter overall.
Purchased one years ago, and have never regretted it.
Mark
Old 06-14-2011, 02:12 PM   #3
Next Time...New Build
Rewards Points: 150
With that much to hang a dedicated drywall gun is definitely a good choice.
The impact does make setting screws a little easier. As you said, you have good control which makes you less prone to run the screw through the paper of the board. I have used my impact on a number of occasions to hang board, but not that type of volume.
Used to use an old Milwaukee drywall gun that ran like a champ.
RickyBobby is offline   Reply With Quote
Old 06-14-2011, 09:02 PM   #4
I have a Senco screw gun and I love it! I use it for everything.
Justin8152000 is offline   Reply With Quote
Old 06-17-2011, 04:05 PM   #5
Rewards Points: 258
With 118 sheets of drywall, i'd buy a screwgun for sure. It will save you a lot of time. i bought one just for 35 sheets. Can't imagine not having one for the quantity you will be putting up.
jburchill is offline   Reply With Quote
Old 06-17-2011, 04:19 PM   #6
Rewards Points: 1,772
Go to:
http://www.bigskytool.com/Drills_Fasteners___c466.aspx
They've some reconditioned ones for < $50. I bought a Hitachi reconditioned drill, recip saw, light, batteries 3 years ago for real cheap. They come with full warranty so how can you go wrong?
I have no vested interest in this company; there may be other such deals out there; this is just an example.
bob22 is online now   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
oh'mike (06-17-2011)
Old 06-18-2011, 09:22 PM   #7
I would go with a collated screw gun, the screws in strips cost a little more, however you can fly with one of these, the time you will save will more than cover the cost of the screw strips, I have both a collated and regular screw gun, for smaller jobs, I will use the screw gun, but if I am going to hang a whole room, I get out the collated. I would not get the screw setter bits for that much drywall, they strip to easy and are a hassle.
bc0604 is offline   Reply With Quote
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 10:35 PM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 09:02 AM
Drywall over Drywall.. NoviceHandyman Drywall & Plaster 6 01-10-2011 08:32 PM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 05:49 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
