Drywall On Rafters In Uninsulated "side Attic" - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-01-2012, 10:29 AM   #1
Drywall on rafters in uninsulated "side attic"
Background:We just moved into a new house. The house is two stories with a steeply pitched roof and dormers (cape cod style?). The bedrooms on the second floor have full sized doors which lead to "side attics". The side attics are unconditioned with vented sofitts and exposed rafter bays that continue un-interrupted into actual attic which has a ridge vent. The walls between the side attic and the rooms are insulated with fiberglass bats.
Problem: Passing cars are very loud in the rooms. I went in the side attic and it appears as though the sound is coming through the vented soffit (and possibly the rood itself. I'd like to try to deaden this sound by installing some sound of sound deadening sheathing on the rafters (just in side attic, not the actual attic). There would still be an uninterupted air flow under the roof deck so I think this idea is ok as far as roof deck venting is concerned. Some internet research I've done is leading me to drywall for both cost and effectiveness. My question is whether or not drywall will hold up to the elements (hot, cold etc) that it will be subjected to under the roof deck. Thanks for your help
bpeters2 is offline   Reply With Quote
Old 02-01-2012, 10:18 PM   #2
Registered User
Rewards Points: 5,520
Welcome to the forums!
You could run baffles clear to the ridge, plastic-not foam: http://www.buildingscience.com/docum...n-roof-venting
Drywall in an unheated area requires exterior gypsum board or soffit board, due to the moisture there.
Gary
Old 02-01-2012, 10:34 PM   #3
Rewards Points: 1,092
Don't know where you are, but are these doors rather expensive, in that they are letting gobs of btu's out (through and around them), besides moisture into the unconditioned space? Have you been through a whole winter there? For noise, is the door sealed well? Is it a heavy door (good for damping noise).
Old 02-02-2012, 08:09 AM   #4
Thanks for the advice. I'll have to check into the baffling for the rafters. GBR, the article you referenced suggested using polyiso foam as one option, is there a reason you suggest otherwise? Any idea why all the baffle options listed in the article are implemented "inside" the rafter bay. Why not just glue polyiso board to the underside of the rafters to create a channel for airflow? Is exterior drywall the same thing as "greenboard" (moisture resistant drywall) used in bathrooms etc?
As far as the access doors....they are just standard hollow core interior doors (circa 1940). I'm thinking about attaching a piece of gypsum (sound deadening) and foam board (insulation) to the back of the door and sealing it well with weatherstripping. Upon further thought, I think it may be better to put drywall on the attic side of the kneewalls (over some new fiberglass insulation)..
Old 02-02-2012, 11:37 AM   #5
get something better if you can. roxul, cotton, wool, etc.
Old 02-04-2012, 04:11 PM   #6
Registered User
" GBR, the article you referenced suggested using polyiso foam as one option, is there a reason you suggest otherwise? Any idea why all the baffle options listed in the article are implemented "inside" the rafter bay. Why not just glue polyiso board to the underside of the rafters to create a channel for airflow? Is exterior drywall the same thing as "greenboard" (moisture resistant drywall) used in bathrooms etc?"--------- you could install f.b. to the rafter bottoms, after air sealing the attic first. This is of primary importance. Positive fastening is required. Check locally with your building department, you may need to cover the foamboard with an approved ignition barrier. i would not use greenboard, research gyprock or U.S.Gypsums soffit board or exterior gypboard.
Gary
Gary
Drywall repair REXAMUS Drywall & Plaster 7 12-21-2011 03:24 AM
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 07:08 AM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 09:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
