Drywall Question- Patching Walls Of 2 Thicknesses - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-11-2010, 04:00 PM   #1
Rewards Points: 31
Question
Drywall question- patching walls of 2 thicknesses
Doing some modifications to my house I've never drywalled before short of some spackling but I'm good with my hands
I forgot to take pics today but figured the knowledeable here would give me some ideas, so I'll try to describe in words.
The house has wall board, layered with mortar ontop and then skimcoated with plaster, so it's pretty thick, just over 3/4" on some walls, and closer to 1/2" and 5/8" on others which brings me to my problem.
I tore down some partition walls in my house so now have to patch where was torn down. At one of these patch areas the walls to be joined one is slightly thicker than the other. The difference is approx 3/8" in thickness. I don't care if it's perfect but it should look half way decent so I'm wondering what's the best way to go about doing this. I'm using 5/8" sheetrock to fill in the space- and the space is 40" wide because I cut down so I could make an in the wall shelf. I plan on trimming out the wall shelf with trim that was used from a door frame a wall that was taken down.
There are some challengers- I have a 4 gang electrical box for switches there right at where the uneven walls meet, so any kind of taper would likely be seen against the relatively wide wall plate cover.
Option 1: I would shim out the "patch" drywall sheet 3/8". I made some shims last night and did some test fitting- it looked good BUT I am worried this will affect the wall shelf trim (with one side being flush and the other having a slight gap) unless the sheetrock flexes enough to conform. And 5/8" doesn't seem to flex too much and even then it may crack later.
Option 2: Put in the sheetrock flat without the shims, sand down as much as I can on the "higher" wall and fill it in and taper the seam as best as possible with tape and setting type compound. The shelf trim will then be flat. BUT- sanding will only get me a little bit of skimcoat off the wall as the mortar is basically sand and stones and will not sand down, and the 4 gang light switch will show any kind of taper pretty easily.
Suggestions?
cbrc5eric is offline   Reply With Quote
Old 11-12-2010, 02:26 PM   #2
sounds like a doozy. my first thought was a mudded taper which is easy, but no good for the electrical issue, and you'll wind up tapering a long ways to take out 3/8".
my suggestions:
1) move the electrical and mud the taper
2) remove more wall on the prouder side, in other words begin the taper further back. then the box should be fine
3) add more wall on the shy side. like a piece of 3/8" sheetrock. if it's a short wall, i would definitely go this route.
good luck.
wombosi is offline   Reply With Quote
Drywall Putty question VinceA Drywall & Plaster 15 11-03-2010 08:42 PM
Question about finishing a drywall corner? Valerie1c Drywall & Plaster 3 08-26-2010 01:30 PM
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 05:58 PM
Question about "cutting-in" walls? diy diva Painting 6 01-13-2009 01:24 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
