#1 |
drywall question
I'm drywalling in my basement, and have a question about drywalling around a chase. The wall in question is about 20 feet across or so, and the chase almost bisects the wall in the middle. But, it only sticks out about 1/8 or 1/4 inch or so. Whats the best way to dry wall over this?
I really don't want to frame a box around it. Any other thoughts/suggestions? thanks
#2 | |
Lic. Builder/GC/Remodeler
drywall questionQuote:
1.) If you are dead set on not having a minor 'bump out there, you could furr out all the rest of the walls (if all ready framed) to meet that chase area in it's wall depth. 2.) Use 5/8" sheetrock only along the wall areas that the chase is on to bring out the depths. On the chase, you could use 1/4" to 3/8" sheetrock to try and make it flush with the rest of the walls along that area. 3.) You could simply go comptely over that area and leave the 1/4" - 1/8" difference there. You would have a slight 'hump' in the wall that would be barely noticable at the floor and ceiling line. 4.) If the other walls are not framed yet; you could just bring out the other walls 1/8" to match the depth of the chase wall and then end up with a completely 'even' wall depth.... It sounds like #2 might possibly be your best option - based on the specifics of your actual question....
- Build Well - Last edited by AtlanticWBConst.; 02-19-2007 at 02:25 PM. |
| Display Modes | |
| Plaster to drywall joint question. | ERIK2173 | Remodeling | 7 | 05-16-2009 05:58 PM |
| Drywall Painting Question | WorkOnIt | Painting | 8 | 06-14-2007 05:12 PM |
| General easy drywall question | bigboyjoel | Building & Construction | 3 | 05-27-2007 09:52 AM |
| Drywall thickness on ceiling question. | Doug Crf | Building & Construction | 3 | 08-28-2006 06:47 AM |
| Drywall question | Not Sure | Building & Construction | 6 | 08-27-2006 04:05 PM |
