-   -   drywall question (http://www.diychatroom.com/f19/drywall-question-6583/)
nasdaqer 02-19-2007 12:51 PM
drywall question
I'm drywalling in my basement, and have a question about drywalling around a chase. The wall in question is about 20 feet across or so, and the chase almost bisects the wall in the middle. But, it only sticks out about 1/8 or 1/4 inch or so. Whats the best way to dry wall over this?
I really don't want to frame a box around it. Any other thoughts/suggestions?
thanks:furious:
AtlanticWBConst. 02-19-2007 12:59 PM
thanks:furious:
Options:
1.) If you are dead set on not having a minor 'bump out there, you could furr out all the rest of the walls (if all ready framed) to meet that chase area in it's wall depth.
2.) Use 5/8" sheetrock only along the wall areas that the chase is on to bring out the depths. On the chase, you could use 1/4" to 3/8" sheetrock to try and make it flush with the rest of the walls along that area.
3.) You could simply go comptely over that area and leave the 1/4" - 1/8" difference there. You would have a slight 'hump' in the wall that would be barely noticable at the floor and ceiling line.
4.) If the other walls are not framed yet; you could just bring out the other walls 1/8" to match the depth of the chase wall and then end up with a completely 'even' wall depth....
It sounds like #2 might possibly be your best option - based on the specifics of your actual question....
nasdaqer 02-19-2007 01:54 PM
sounds good
I appreciate all the suggestions!
