Drywall Paper Question? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 12:47 PM   #1
wraiththe's Avatar
Rewards Points: 99
Drywall Paper question?
Hi,
My purple board has lost some of the paper on it. Not all of the paper, but some. Also some on some greenboard as well. I alreayd have to compound some tape and corners in the area. Can you just use joint compound over these areas as well, or is there a better way? i have included a picture of several areas.
wraiththe is offline   Reply With Quote
Old 12-30-2011, 07:24 PM   #2
wraiththe's Avatar
Rewards Points: 99
WOW, 72 views, no answers.
Answer; cut out layers that are frilly as much as possible... if you do not go down to the gypsum (not sure what to coat that with) then coat it with a Primer Sealer. Some said Oil Base.... I used a water base like Bulls eye or Gardz or Kilz
http://www.lowes.com/pd_40863-90-047...ulls&facetInfo=
Well, I hope anyway.
Old 12-30-2011, 08:44 PM   #3
I can't remember where I found this, but it worked well for me.
1) Cut away all the fuzzy paper edges, but stay as shallow as possible.
2) Prime the exposed gypsum, as well as the cut edges with PVC primer.
3) A thin coat of hot mud (I used 90 minute...so maybe not all that hot...) to bring the surfaces even.
4) Thin coats of joint compound, sand, repeat...
5) Prime, sand, finish.
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Drywall question Vikeologist Drywall & Plaster 28 01-13-2010 08:17 AM
proper method for paper faced drywall corners rocketdoctor Drywall & Plaster 2 12-06-2009 10:14 AM
Frustrated by paper along side of drywall J187 Drywall & Plaster 6 04-22-2009 05:29 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Drywall question Not Sure Building & Construction 6 08-27-2006 03:05 PM
