Drywall Opening In Ceiling Too Large For Heat Vent Unit - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-17-2013, 10:37 PM   #1
Drywall opening in ceiling too large for heat vent unit
Am replacing heat-vent-light unit in ceiling, and current opening is about 3" wider than unit (after grill is installed). What can I use to 'close in' the opening (trim?) so the grill of the unit will completely cover the drywall?
Thanks for any suggestions...
jaym is offline   Reply With Quote
Old 02-17-2013, 10:41 PM   #2
Rewards Points: 12,812
Sheetrock, plaster?
If it's sheetrock just cut out a hole with square corners that bigger then the light and install a new piece of sheetock using strips of 2 X 4's laying flat to screw to.
Old 02-17-2013, 10:55 PM   #3
Are there thin plastic moldings available that could be mitered and glued to sheetrock and surround the grill?
Drywall ceiling issue DIY NOOB Drywall & Plaster 9 10-28-2012 08:56 PM
Drywall doesn't line up on ceiling thebrandnewguy Building & Construction 6 09-14-2011 08:23 AM
Basement framing - drywall ceiling question tmhouse Building & Construction 1 07-11-2011 01:11 PM
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 02:23 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
