Drywall Mud Types - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-03-2007, 11:26 PM   #1
Rewards Points: 24
drywall mud types
I usually use the premixed pails of mud but was wondering about the bags. They have a 20,40, and 90 minute setup bags available and others like all purpose. When do you use each type of mud? Will the 20 minute mud crack easier than the 90 minute or all purpose which takes 24 hours to dry? Just curious on these fast setting compounds and when to use which ones. Thanks
ponch37300 is online now   Reply With Quote
Old 12-03-2007, 11:47 PM   #2
Originally Posted by ponch37300 View Post
I usually use the premixed pails of mud but was wondering about the bags. They have a 20,40, and 90 minute setup bags available and others like all purpose. When do you use each type of mud? Will the 20 minute mud crack easier than the 90 minute or all purpose which takes 24 hours to dry?Just curious on these fast setting compounds and when to use which ones. Thanks
Here is a link to help you with your questions:
http://www.usg.com/navigate.do?resou...t_Compound.htm
If you use fiberglass mesh tape, you should use the quick drying mud; not All-Purpose. Otherwise, all of the butt joints will crack. Depending on how much you have to tape, you can choose the appropriate drying time. Personally, I would use no less than the 45 minute mud. It will give you time to do allot of taping before it begins to harden. It is best to smooth it as much as possible, because it is difficult to sand after it hardens. Once the tape is bedded, then you can use All-Purpose on top of it. Use a Lite topper mud to finish the job.
Q: Will the 20 minute mud crack easier than the 90 minute or all purpose which takes 24 hours to dry?
A: No. Any of the Durabond muds are harder than the drywall. They won't crack easily. However, the All-Purpose mud will definitely crack on the butt joints with mesh tape, as I said.
Handyman50 is offline   Reply With Quote
Old 12-04-2007, 04:51 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
We use each type based upon the needs of a particular job application.
Examples:
Small hole patch that needs to be re-coated and sanded "asap": We use a 5 minute or a 15 minute dry-mix. Can be finished-off quickly.
Small dry-wall job: Let's say, we have a small basement renovation, and we have 3-4 tapers working on. We will use either a 45-minute (4 tapers) or a 90-minute (2 tapers). (4 tapers will fly-through/empty - a bucket of compound VERY quickly). By using a quick-set compound, we have been able to completely tape and finish (minus the sanding) basements in one day.
If we have alot of corner bead and soffits; we would use a 90 minute, because it takes longer to apply it all and "tie-in" the various areas.
In our Drywall trucks, we always keep a selection of 5 minute, all the way up to 90. Especially, this is the case in the winter-time, when ready-mixed buckets of compound will freeze.
So, in essence, the difference in using each compound is based on the time requirement needs.
As already answered - No.
- Build Well -
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 05:59 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
