Drywall Mud Over Paint? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-22-2011, 11:42 PM   #1
Question
drywall mud over paint?
I'm drywalling a ceiling in a little remodel. I'm installing the wallboard over existing acoustic tiles, and putting a vapor barrier in, taking out some fluorescents and dropped ceiling, and putting in cans. That part shouldn't be a problem.
My question is: can I mud over existing paint? See the area between the wallpaper and the ceiling tiles? There is some molding I need to remove, but that area has some sort of paint over drywall. Can I tape and mud over that with any luck? If I can't I can carefully remove the molding and replace it, but I'd prefer a cleaner look.
Hope someone has a yes or no answer. Thanks
Oh yeah, and never mind the crazy wire going into the gaping hole.
Geronimo411 is offline   Reply With Quote
Old 08-22-2011, 11:56 PM   #2
solution
Found this post:
http://www.contractortalk.com/f49/im...d-walls-51187/
Many, many, many solutions----maybe.
Old 08-23-2011, 06:14 AM   #3
Mud will stick to almost anything, but if the paint bond loosens over time so will the mud.
Old 08-23-2011, 09:21 AM   #4
Too Old
I would recommend using all purpose mud, I have gone over paint and wallpaper numerous times and never had an issue, on wallpaper it's a pain because when it bubbles you have to pull that area out recoat and if it the paper bubbles more then you keep going. One house we bought had 2 rooms that were wallpapered, it was easier to have the wife take 4 days removing the wallpaper
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Tags
drywall , mud , remodel , tape , wallboard
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
How to mix color (paint) in with drywall mud? Snav Painting 17 10-11-2011 08:43 PM
Drywall Repair - Paint peeled off down to drywall TJoy Drywall & Plaster 5 06-24-2011 02:48 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
Primer vs. Flat paint lovetrading Painting 3 08-22-2008 08:13 PM
