Drywall Metal Corner Connectors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-26-2011, 03:33 PM   #1
drywall metal corner connectors
Not really sure where to put this so i will try here. The metal strips connecting the corners of drywall are coming off and want to know how to fix them before I paint. I have a couple of pictures.
Thanks,
H.O.P. is offline   Reply With Quote
Old 05-26-2011, 07:49 PM   #2
DIY staff
Rewards Points: 7,174
I use a 1/4 inch small crown stapler----however,using drywall nails work well,too.
Fill the metal corner bead with 20 minute 'easy sand'--that's the powdered mix.
If you don't like mixing mud then All purpose will do--it's not as hard as 2- minute,but acceptable.
Avoid using light weight topping mix as it doesn't stick very well.---Mike---
Corner Metal Pieces (brace) for outside cordners Needed Before Tile jwhiteuwc General DIY Discussions 1 02-03-2009 12:57 AM
filling gap in drywall corner listo Drywall & Plaster 6 01-27-2009 09:29 PM
Drywall Corner Confusion Melanie337 Drywall & Plaster 5 01-18-2009 10:01 AM
Corner Bead....Metal or Plastic? yummy mummy Building & Construction 2 01-23-2008 06:11 PM
Flexible metal corner bead? Worth using? yummy mummy Building & Construction 3 11-15-2007 07:09 PM
