Drywall Into Ceiling Joists? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-25-2007, 12:55 AM   #16
Originally Posted by jiggyjack View Post
Use 5/8s rock!! You will regret it in a couple of years if you use half.
Rent a lift there like $30.00 a day where I'm from, hell even if you use half a lift is still worth it.
I have to ask. Why will he regret using 1/2 inch.
warnerww is offline   Reply With Quote
Old 08-25-2007, 01:00 PM   #17
5/8 regular is fire resistant? I thought this was a special drywall called something like type x that had to be used?
guess i'll have to research this for my house, because I only require 1 piece against my garage/house and it has to be type x not regular drywall
Mike
mike canton is offline   Reply With Quote
Old 08-26-2007, 08:54 AM   #18
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
My thought too: We have beams that we hung 20+ years ago with 1/2" Sheetrock that still have zero problems....
- Build Well -
Old 08-26-2007, 03:38 PM   #19
Mike
5/8" Type X sheetrock is "Fire-rated', not "fire-resistant".
It is rated as "one hour" fire protection per full wall layer.
More information:
http://www.nationalgypsum.com/resour...tyinformation/
- Build Well -
garage ceiling joists josh123 Carpentry 6 07-15-2009 12:07 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
Question about ceiling joists... StlJoe Building & Construction 5 12-06-2005 12:52 PM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-14-2005 12:16 AM
