#1 |
Drywall into Ceiling Joists?
Is it ok to hang drywall directly into your ceilign joists? I've heard both yes, and no.
I don't really want to go to the trouble of cross beaming a ton of metal furring chnnels, mainly because the recessed lights i have up there won't be able to sit down far enough from where they are attached to the joists. Any feedback much appreciated. |
#2 | |
Drywall into Ceiling Joists?Quote:
#3 | |
By strapping, do you mean adding on a little furring, with some shims if needed (to level everything out?) I've checked the the ceiling with a level, and it appears to be very good. As far as obstacles, there's tons of wiring, but it's all run thru the pre-cut holes in the middle of the joists, so i don't ahve to worry about any of that. The only thing im worried about it the floor flexing a little over time, because it is walked over (above) a lot. Is this an issue, or ? |
#4 |
Depends on the span, but I would say a safe bet is go ahead and install onto the joist. If deflection is a big problem then straps are not going to help much.
#5 | |
#6 | |
Lic. Builder/GC/Remodeler
For instance: Tile flooring is placed on 2nd and 3rd level floors and does not have deflection problems on "modern day, normally constructed homes". You should not have issues with your beams being wrapped in sheetrock, unless you have some serious and unusual load bearing and structural issues in your home. Here's an example of furring out a beam with wood "strapping" in order to add sheetrock and hide electrical wiring (wiring is for two ceiling fans): ![]() ![]()
- Build Well - Last edited by AtlanticWBConst.; 08-18-2007 at 05:24 PM. |
#7 |
Hang the drywall you are fine. The only reason to use 5/8 rock is fire protection ( I do recommend that).
#8 | |
That one wall was hung with 5/8" because it was a fire-rated separation wall connected to the garage.
- Build Well - |
#9 |
...and actually, the more dense a material is, the less it flexes, and the more likely it is to "crack".
Thus, 1/2" S/R is less likely to crack than 5/8" S/R in an area that has settling or unusual deflection issues...
- Build Well - |
#10 |
Extreme DIY'r Adk's, NY
Good point, hey fire code here requires double layer of 5/8 between attached garage and house... you too? So if it's new construction I put 5/8" on both sides, if it's an add on garage you have to put two layers in the garage on the mating wall.
#11 |
Code here is 1 layer of fire-rated 5/8" for such a structural residential design.
- Build Well - |
#12 |
Some fire-rating information regarding partition walls and wall materials:
http://www.cdc.gov/nasd/docs/d001501...9/d001529.html
- Build Well - |
#13 | |
They make a self drilling 1 1/4" screw for metal beams. Do you have the 20 guage or 25 guage metal beams? |
#14 |
Definitely just hang it on the beams if it inst out of level and wavy. There is no reason why you shouldn't be able to hang it on the beams, i personally always do. As for 1/2 vs 5/8 i personally would take the 1/2. 5/8 rock is about 70-80 pounds a board i believe, and its not fun putting up a board of 1/2 on a ceiling let alone 5/8. And don't anybody say, o its not that heavy i don't care who you are, putting 5/8 on a ceiling is no picnic.
dadflyn, its called a self tapping screw. Hilti makes great ones in all sizes they also make them for heavy gauge metal. As far as 20 or a 25 gauge beam, i hope you are talking about studs and track for framing because if your house has a structural beam made of 20 or 25 gauge metal you have sheet metal holding up your house. |
| Display Modes | |
| garage ceiling joists | josh123 | Carpentry | 6 | 07-15-2009 12:07 AM |
| Drywall thickness on ceiling question. | Doug Crf | Building & Construction | 3 | 08-28-2006 06:47 AM |
| Basement Ceiling- Combo of Drywall and Drop ceiling? | H Thomas | Building & Construction | 5 | 03-27-2006 09:27 AM |
| Question about ceiling joists... | StlJoe | Building & Construction | 5 | 12-06-2005 12:52 PM |
| Spacing of ceiling joists | Pineconeman | Building & Construction | 3 | 05-14-2005 12:16 AM |
