Old 09-19-2010, 08:45 AM   #1
Drywall installed over plaster
I am looking into purchasing an old home with plaster walls. The walls are in bad shape and I rather not remove the plaster if I dont have too.
The question I have is, Can I have drywall installed over the plaster and just bring the electrical boxes out?
brait97 is offline   Reply With Quote
Old 09-19-2010, 08:50 AM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
1/4". Easier pulling the Plaster walls, so that wiring can be updated, along with Ethernet, CATV & Telephone pulled in various places, and insulation on outside walls installed.
gregzoll is online now   Reply With Quote
Old 09-20-2010, 05:28 PM   #3
Over the years I have worked on many old southern homes, homes Sherman did not burn to the ground, and they all had plaster walls, some walls were level others wavy. In some instances I used 1/4 inch drywall and others 1/2 depending on what shape the walls were in. The contractors had gone in and put in new wiring and plumbing and when I came in we just sheetrocked over the existing walls. I have done several renovations in Atlanta where all the homes were plaster, I put drywall on both ceiling and walls, and on one job I butted drywall to the plaster. If you are doing it yourself, use longer screws.
newfie49 is offline   Reply With Quote
Replacing damp drywall / plaster in shower Elcontador Drywall & Plaster 2 02-25-2010 06:03 AM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Can you adhere drywall to plaster? whiskeykid Drywall & Plaster 9 08-15-2008 08:42 AM
Repairing Ceiling Crack Seam bakerhouse Building & Construction 6 05-05-2008 03:56 PM
Plaster and Lathe walls- covering with drywall Jrr1099 Building & Construction 4 03-24-2008 03:20 PM
