Drywall Installation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-25-2012, 06:06 PM   #1
Solutions (handyman)
Rewards Points: 364
Drywall installation question
I am installing drywall on the front wall of a quonset. The walls and ceiling are one continous curve, The drywall will not be holding any ceiling material (as in normal room installation) so my question is this; is it best to start from tyhe bottom and work my way up or top down? Any tips are appreciated.
Mark Harvey is offline   Reply With Quote
Old 10-25-2012, 06:31 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,242
how tall is the ceiling.. if its fairly high i woiuld start from the floor making sure you keep the board 1/2" off the floor so it doesnt take on moisture if the floor floods.
by working from the bottom up when you start getting up into the radius you will have a "hard surface to take your measurements off for figuring out the arc. you can make reference lines on the last sheet to then transfer marks on to the next sheet being hung
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
mae-ling (10-26-2012)
question on foam board installation ROB62 Insulation 3 05-09-2012 11:28 PM
Remove plastic before drywall installation? avgor Drywall & Plaster 6 01-23-2012 08:03 PM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 09:32 PM
Question about putting up drywall CZ DIY Building & Construction 5 02-25-2010 09:41 AM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
