Drywall Hanging Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-07-2008, 03:28 PM   #1
Rewards Points: 150
drywall hanging question
what is the UBC requirement for hanging (screws) drywall?
Perimeter screw spacing? Field screw spacing? Different for 1/2" and 5/8"? Different for walls vs ceiling?
Thanks in advance.
steve1234 is offline   Reply With Quote
Old 05-07-2008, 04:52 PM   #2
google son
AndyH is offline   Reply With Quote
Old 05-08-2008, 06:15 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
It's listed on Table R702.3.5 - Application of Gypsum Board
This is with screws (Not nails - nail requirements are different):
None listed. (You should install every 16")
1/2" GWB - Walls with 16" OC framing: Every 16"
No.
5/8" GWB - Walls with 16" OC framing: Every 16"
Yes.
1/2" GWB - Ceilings with 16" OC framing: Every 16"
1/2" GWB - Ceilings with 24" OC framing: Every 12"
5/8" GWB - Ceilings with 16" OC framing: Every 16"
5/8" GWB - Ceilings with 24" OC framing: Every 12"
Requirements when using adhesives with the screws:
1/2" & 5/8" - Ceilings with 16" OC framing: Every 16"
1/2" & 5/8" - Walls with 24" OC framing: Every 24"
- Build Well -
The Following User Says Thank You to AtlanticWBConst. For This Useful Post:
DangerMouse (04-05-2011)
Old 05-08-2008, 02:44 PM   #4
Rewards Points: 150
Atlantic-
AWSOME.....thanks for the info. Very helpful.
drywall question billyg Drywall & Plaster 3 08-01-2008 09:49 PM
Hanging Drywall Perpendicular To The Floor? DIYScott Remodeling 8 10-03-2007 08:47 AM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Drywall question Not Sure Building & Construction 6 08-27-2006 03:05 PM
