Drywall Hanging HELP!! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 07:35 PM   #1
Drywall hanging HELP!!
Hey all,
I have read 100 different postings and forums and DIY Network videos but I still have a question about hanging drywall vertically or horizontally.
I have heard alot of people talk about hanging horizontally because of less seams and strength of the horizontal edge along the ceiling. My main question I guess is that since I only have 7' ceilings, hanging the drywall vertically would let me cut 1'x4' section off each 4'x8' sheet instead of a 1'x8' section on half of the sheets, making less waste. Also all of my seams would be the tapered long edge vertically except where the ceiling and wall meet.
Would this be the way to go or still go horizontally? Please let me know if you have any actual advice instead of just nonsensical jokes or comments? I know alot of you have good info to pass on. Thanks in advance.
topflitecop21 is offline   Reply With Quote
Old 01-16-2012, 07:43 PM   #2
I typically hang my drywall vertically because I don't like to tape horizontally.
Less waste is good too, like you mentioned.
Good luck,
Dave
Bluehawks is offline   Reply With Quote
Old 01-16-2012, 07:56 PM   #3
Crusty Old Dude
Big Stud's Avatar
Horizontal is definately stronger and the way most ros do it.
I have seen it done vertically, and have noticed you can see the seams more easily when it is finished,
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
The Following User Says Thank You to Big Stud For This Useful Post:
Willie T (01-16-2012)
Old 01-16-2012, 08:06 PM   #4
Concrete & Masonry
Rewards Points: 650
I don't see how you're making any less waste with having twice as many 1'x4' cut-off's vs. 1'x8'?? I'm fairly sure you'll be tossing about the same aamount away.
If you are trying to avoid butt-joints, you can shim out every stud but the studs at the joint to help depress the joint as well as many other options. I'd agree with above though that it's harder to hide vertical seams of 7' tall sheets.
jomama45 is offline   Reply With Quote
Old 01-16-2012, 08:24 PM   #5
Well I guess you're right about the waste but shimming every stud seems to be quite a time and material waster. Is this something that is regularly done? Also I don't know if it matters but it's for a basement.
Old 01-16-2012, 08:25 PM   #6
Good luck,
Dave
Sweet. Do you have any pics to disprove the bad seam quality in vertical hanging?
Old 01-16-2012, 08:44 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 2,142
There is one fatal assumption to the vertical method........
That you have EXACTLY 4' spaced studs (at 16" OC) and that they are totally straight up the wall. All it takes is for the stud that is supposed to be at the 4' mark, be off by 1/2". Kind of hard to stretch a 4x8 sheet 1/2".
The Following User Says Thank You to ddawg16 For This Useful Post:
mae-ling (01-16-2012)
Old 01-16-2012, 09:03 PM   #8
retired union carpenter
Send a message via Yahoo to coupe
"Sweet. Do you have any pics to disprove the bad seam quality in vertical hanging? "
you don't need pictures? go into any office building where stand up sheets were used. simply follow the ceiling angle you can see every joint.
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
The Following 2 Users Say Thank You to coupe For This Useful Post:
mae-ling (01-16-2012), woodworkbykirk (01-16-2012)
Old 01-16-2012, 09:21 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,360
vertical joints create more joints for the tape.. and they have to kneel to tape the bottom half.. by running the sheet horizontaly they only have to deal with the angle joint at the ceiling and one joint waist height unless the wall is longer than the sheets bought..
as for how vertical sheets look, it does look terrible.. unless you have a taper that can do a level 5 finish your going to see the joints especially if its on wood framing. its a commercial method used for curtain walls.
woodworkbykirk is online now   Reply With Quote
hanging ceiling drywall in a basement charlie bob Drywall & Plaster 5 06-21-2013 11:30 AM
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 09:50 AM
Cost for hanging sheetrock and drywall in Central Florida ecogardengroup Drywall & Plaster 8 10-27-2011 09:21 AM
Hanging Drywall x106 Drywall & Plaster 20 05-12-2011 11:40 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
