Drywall Edges - Bead Or No? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-09-2007, 04:12 PM   #1
Drywall Edges - bead or no?
Drywall hanging question regarding the finish out around a window opening.
I have 2x6 walls with the windows inset such that I have about 3 1/2 to 4 inches of "sill" space around the inside of each window. I plan to trim out the windows with 1x maple stock and some molding.
Question is the drywall - we have hung the walls with flush cutouts at each window opening. Do we have to install "J-bead" where the drywall edge meets the window well opening?...or since this cut edge will be covered with trim wood - do we not use edging bead?
Thanks.
Rick
Ricky D is offline   Reply With Quote
Old 07-09-2007, 07:42 PM   #2
Extreme DIY'r Adk's, NY
Rewards Points: 254
general practice is to leave alone when covered by molding. In fact anything more and you would probably be considered "OC" by sheetrockers.
crecore is offline   Reply With Quote
Old 07-09-2007, 07:52 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You must mean "jamb" space (for the window's side jambs, header stock and bottom sill stock.
As stated already: That's good enough right there...for your finish trim work...
- Build Well -
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 05:59 PM
Mounting corner Bead KUIPORNG Remodeling 7 01-04-2007 08:20 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
