-   -   Drywall Edges - bead or no? (http://www.diychatroom.com/f19/drywall-edges-bead-no-9770/)
Ricky D 07-09-2007 05:12 PM
Drywall hanging question regarding the finish out around a window opening.
I have 2x6 walls with the windows inset such that I have about 3 1/2 to 4 inches of "sill" space around the inside of each window. I plan to trim out the windows with 1x maple stock and some molding.
Question is the drywall - we have hung the walls with flush cutouts at each window opening. Do we have to install "J-bead" where the drywall edge meets the window well opening?...or since this cut edge will be covered with trim wood - do we not use edging bead?
Thanks.
Rick
crecore 07-09-2007 08:42 PM
general practice is to leave alone when covered by molding. In fact anything more and you would probably be considered "OC" by sheetrockers. :wink:
AtlanticWBConst. 07-09-2007 08:52 PM
You must mean "jamb" space (for the window's side jambs, header stock and bottom sill stock.
As stated already: That's good enough right there...for your finish trim work...
